Camshaft removals
Camshaft removals
Once again, I turn to the experts on how to solve my problem of removing the right camshaft. Left side came out after some aggressive persuasion. It seemed like the splined end of the shaft was "stuck" in the camshaft sprocket. Now the right one won't let go. What I can't figure out is the purpose of the camshaft locking bolt. Does it lock the right camshaft to the sprocket? I have the nut loose but tapping on the treaded end results only in the whole camshaft assembly moving in the head bearing bores. How is the camshaft separated from the sprocket?
mike in idaho
The camshaft locking bolt has a tapered head that expands the id of the camshaft a few thousandths to grip the center. Loosen the nut on the bolt and tap(lightly) on the end of it to release it from the taper. I unscrew the nut until it is flush with the end of the bolt and tap it with an eight ounce hammer.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
Camshaft removal.
You might need to use a bigger hammer! protect the threaded end by laving the nut in place, than give the nut a clout, as hard as necessary, if you need to, support the other end of the cam, When it's free the bolt will be loose in the cam which should then come out of the sprocket OK.
You've got to release that taper before you can get the cam apart and the cam is pretty bullet proof.
As DJM says - run the nut off so that it is flush with the end of the thread and give it firm blows with a (2lb) hammer. The taper will give way and the nut will move up to the end of the cam.
If it doesn't move, you haven't hit it hard enough.....
jnbmoore wrote:DJM,
How hard a smack should I give it? Kinda gun-shy here as I hate to break or bend something. That locking bolt is in there real tight although I can squirt some PB Blaster at the bolt threads and it'll come out from the cam sprocket on the other end.
Anyone have any other tips here?
