CB77 Superhawk Aftermarket Headlight
ChromeSuperhawk
Post by ChromeSuperhawk » Sun Dec 02, 2018 5:06 pm
I have a 1967 Superhawk that I'm looking to upgrade the lighting on. Has anyone tried to install aftermarket LED headlight in the original headlight bucket? What are some turn signals that would be recommended? My CB77 is mostly OE, but I'm not really worried about the lights being modern for visibility and current draw benefits. Thanks for the help.
Post by G-Man » Thu Dec 20, 2018 10:24 am
Use a European headlamp reflector which has replacement bulbs. You can use whatever bulb you wish, then.
http://www.norbsa02.freeuk.com/goffyWhyNotLEDs.htm
cknight
Post by cknight » Thu Dec 20, 2018 10:44 am
Hi G, the replaceable bulb style units that I used to obtain from Candlepower here in the US were called 162mm (6-3/8") diameter. They did fit just a bit on the loose side in the CB72/77 stock rim. Do these 7" (177mm) units fit without rim issues? Regards, Chase
Post by G-Man » Thu Dec 20, 2018 11:28 am
Chase
That is a standard Honda (Stanley) unit that was supplied for all European market CB72/77.
https://www.cmsnl.com/honda-cb72-hawk-6 ... BvCbC2cYpQ
Part 33120-268-010 to 33120-268-070
US part 33120-268-670 (sealed beam)
cknight wrote:Hi G, the replaceable bulb style units that I used to obtain from Candlepower here in the US were called 162mm diameter. They did fit a bit on the loose side in the CB72/77 stock rim. Do these 7" (177mm) units fit without rim issues? Regards, Chase
cknight
Post by cknight » Thu Dec 20, 2018 11:36 am
Got it. I was looking further down the page at the Wipac Lucas replacement lens that would fit a rim with a 169mm opening. Thanks, Chase
Post by G-Man » Fri Dec 21, 2018 6:57 am
Hi Chase
For some reason, a number of NOS replaceable bulb headlamp units have come up in the last year. I managed to buy a couple.
cknight wrote:Got it. I was looking further down the page at the Wipac Lucas replacement lens that would fit a rim with a 169mm opening. Thanks, Chase
bill440cars
Post by bill440cars » Fri Dec 21, 2018 11:09 am
Some really good to know info. I am glad I happened to come over here, to see if there was any decent activity gong on here, besides the scammers. Glad I made the effort. Bill
Working Toward Being Able To Work On MY Motorcycle Projects (Trying To Get Past "Other" Projects & I Think I Am Making Progress?
