Hotter plugs
casamere
Hotter plugs
Post by casamere » Thu Jan 31, 2019 11:16 am
Can someone offer advice in using D6HA plugs in my CA77 rather than the D8HA I use now.
I have no issues with the 8HA but just seeking advise. Thanks.
DJM
Plugs
Post by DJM » Thu Jan 31, 2019 12:12 pm
If you have no issues with the D8HA plugs why change?
casamere
Post by casamere » Thu Jan 31, 2019 12:58 pm
Fair point DJM but that's not what I was asking.
DJM
CA77 plugs
Post by DJM » Thu Jan 31, 2019 3:23 pm
The modern D6HA / HS and D8HA / HS have a much wider heat range than the 1960s OEM D6H or D8H
If you could see it on a chart I suspect that both] of the modern D6HA and D8HA would each have a heat range that covered that of both of the older plugs, hence plug selection is less critical today.
I don't have a C or CA but use D8HS plugs in both my CB77 and CL77s.
Under the old wisdom I should fit D10H for faster work and stick with D8H for town use but the modern D8HS copes well with both, no misfiring or plug fouling
Back in the day, Honda in the US actually issued a Bulletin to owners saying that they should carry and fit different plugs and change them depending on usage but that's certainly not necessary with today's plugs.
casamere
Post by casamere » Thu Jan 31, 2019 5:31 pm
Thank you sir.
