Removing muffler on CL77 Exaust
Might be a dumb question but I cannot, for the life of me, get the 'guppy' muffler off of my Exhaust. My bike didn't originally have the exhaust with it and I bought is one off ebay and just want to run the straight pipes since I like the look better. It seems like it should just slide out but no luck. Am I missing something?
CL77 Muffler
That's right, the early mufflers were a simple slip on over BOTH pipes with a figure of eight rubber seal.
These were easy to take off and throw away so Honda started to weld them onto (I think) the upper pipe to stop them being removed.
I think that's why you seem to find a lot of CL77 exhausts that have been shortened by a few inches, If you really want to remove the muffler cut the upper pipe through just in front of the muffler box and then cut the lower pipe to match, not pretty though.
Personally I don't much care for the muffler but probably wouldn't cut one off if I had one.
BTW, Although the first generation CL72s, came without the muffler, I think ALL CL77s, even the early 1965 small brake bikes, came with one fitted but a lot seem to have 'lost' them over the years, mine included.
CL77 Muffler work round
Yes there is a work round but not easy.
Cut of the muffler as described and then lengthen the shortened pipe by welding a new piece onto it.
You need access to an early pair to check the that you get the correct length and you may need to lengthen the lower pipe too. I'm not sure if the extension pieces are just straight sections of tube or if they need a slight bend in them.
Finally you will need to get the complete exhaust system rechromed.
Not easy but if you find a decent welder it can be done, there are several bikes (my own included) over here in the UK that have been modified this way.
Personally I think it's well worth the effort as I think the CL77 muffler is one of the ugliest things ever to come out of a Honda factory but that's just my opinion of course.
Easier might be to keep looking on E-Bay for an early set of pipes, BTW individual early and late pipes don't interchange, only as a pair.
Man, that unfortunately sounds a bit out of my league.
Okay next question...anybody have a set of pipes they want to sell? I have the heat shields already so just need the exhaust.
As for the exhaust I have, I guess ebay is the way to go. I got a really good deal on these (which is why I bought them to begin with) so I'll definitely profit. I just think it'd be wrong to run this bike with anything other than the straight pipes :(
mike in idaho
Re: CL77 Muffler
On mine, I cut the muffler, just outside of the weld. Then I ground the weld down smooth, leaving both pipes the correct length.DJM wrote:
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
