Drilling CL 72 crank for a stater clutch
Kthomas55
Post by Kthomas55 » Sat Apr 13, 2019 5:21 pm
I saw one thread that referred to doing this but it was somewhat vague. Can this be done successfully without dismantling the crank ? If so, how would you remove the swarf from drilling ? I have screwed up and installed a cl crankshaft . It was the best one I had and didn’t know about the hole until I ran across a former thread
Re: Drilling CL 72 crank for a stater clutch
Post by G-Man » Sun Apr 14, 2019 12:10 am
I planned to do this but didn't need to in the end.
I'm not sure that the hole in the inner side of the crank web is deep enough but I can check.
For drilling I bought some Artu 2mm drills. http://www.artu.com
To minimise swarf into the engine you could use a vacuum cleaner as you are drilling and drill upside-down. It might be better to pull off the bottom case and perform the opertionwith the crank accessible.
Good luck!
Kthomas55 wrote:I saw one thread that referred to doing this but it was somewhat vague. Can this be done successfully without dismantling the crank ? If so, how would you remove the swarf from drilling ? I have screwed up and installed a cl crankshaft . It was the best one I had and didn’t know about the hole until I ran across a former thread
Kthomas55
Drilling
Post by Kthomas55 » Mon Apr 15, 2019 2:21 pm
Did you happen to check to see if it was deep enough ?
Thanks
Re: Drilling
Post by G-Man » Mon Apr 15, 2019 4:13 pm
Sorry, I've had a busy day. Will check tomorrow.
Kthomas55 wrote:Did you happen to check to see if it was deep enough ?
Thanks
Tim Miller
Post by Tim Miller » Mon Apr 15, 2019 4:44 pm
I just checked four different CL72 crankshafts that are apart and yes they are all drilled deep enough. I would uses some grease on the drill bit to collect the chips then vacuum out hole.
Tim
Kthomas55
Drilling
Post by Kthomas55 » Mon Apr 15, 2019 6:37 pm
Thank You
As soon as I get some decent drill bits I’ll let you know how it turns out
Kthomas55
Drilling crank
Post by Kthomas55 » Fri May 10, 2019 7:08 pm
I ordered bits from my local Fastenal. The just barely made a dent. They said the next price up was 30+ dollars apiece for a 2mm bit. I’m either going to try one more time by ordering some bits or buy another crank. These were cobalt bits.
