CB160 Spun Camshaft Sprocket
CB160, CB350, CB360, CB450
SteveAllenHonda
Post by SteveAllenHonda » Fri Jul 05, 2019 3:36 pm
Hello All,
Went to purchase a Red 1969 CB160-been sitting many years.Hmmm-kicked over,good compression.Took it home,new battery,carb clean,points etc.Won't run.No spark-valves not
actuating.Suspected a broken camshaft chain.Engine apart and I see nice chain connected-
spun sprocket! I can see no marks of how to orient the correct degree if I were to get it welded in lieu of just purchasing another one.Have any of you encountered this?Also-I see no splines or evidence of how the sprocket was affixed in the first place!
Inquiring Minds want to know.
Thanks, Eric
Re: CB160 Spun Camshaft Sprocket
Post by G-Man » Sat Jul 06, 2019 3:05 am
I think they are just shrunk on. I have one with a loose sprocket, too. Should be able to copy the alignment from another sprocket/cam.
SteveAllenHonda wrote:Hello All,
Thanks, Eric
SteveAllenHonda
Post by SteveAllenHonda » Sat Jul 06, 2019 10:49 am
Thank You for the reply.That makes sense-shrunk on.Wonder how many have rotated slightly over the years leading owners with timing problems and no easy way to ascertain the cause!
Eric
