Hey I need a neutral switch for my CB72, this has a code of 35750-259-000
https://www.cmsnl.com/honda-cb72-hawk-6 ... Z_xEUYzaUk
It looks the same as a neutral switch from a CA77, but this has a code of 35750-268-000
https://www.cmsnl.com/honda-ca77-1960-1 ... Z_xsEYzaUk
Does anyone know if there is a difference or are they interchangeable?
Cheers,
Greg
CB72 Neutral switch vs CA77 neutral switch
Neutral switch.
I'm sure the switches will be the same as all of the gear selection parts, drum, forks and mechanism are interchangeable between the CA, CB and CL models, only the actual gears and shafts being different. No reason at all for the switches to be different.
Re: Neutral switch.
They are the same. ............lm
DJM wrote:I'm sure the switches will be the same as all of the gear selection parts, drum, forks and mechanism are interchangeable between the CA, CB and CL models, only the actual gears and shafts being different. No reason at all for the switches to be different.
