disassembling cb77 steering stem
Hank Dymale
Post by Hank Dymale » Thu Nov 14, 2019 4:08 pm
Is it possible to remove the center tube from the lower cast yoke on a CB77 steering stem? The fine threads on the center tube were ruined during disassemble. I have a spare steering stem (33mm), but I have to use my original lower yoke with the 34.5mm I.D. holes to match front forks. I know this is a little long winded question, but any advice would be appreciated.
Re: disassembling cb77 steering stem
Post by LOUD MOUSE » Thu Nov 14, 2019 4:23 pm
NO.. .....................lm
Hank Dymale wrote:Is it possible to remove the center tube from the lower cast yoke on a CB77 steering stem? The fine threads on the center tube were ruined during disassemble. I have a spare steering stem (33mm), but I have to use my original lower yoke with the 34.5mm I.D. holes to match front forks. I know this is a little long winded question, but any advice would be appreciated.
Post by G-Man » Fri Nov 15, 2019 1:40 am
Hank
Those parts were made as two separate pieces so, technicaly, it is possible to take them apart but you would need a big press, some special fixtures and, possibly, heat.
What damage do you have on the original stem? You may be able to use a thread file on the damaged part.
Almost anything can be repaired if you are patient........
I built my own tooling to dismantle and reassemble Honda crankshafts.
