Ca77 transmission problem after rebuild
I have a 1966 Dream.I went through the motor and transmission changing anything out of spec. and of course all new seals and o-rings exc...I have a machinist background so I "Mic"d everything.My problem is it wont go into any gear.Only stays in neutral.I could shift the gears before I put the covers back together and sealed it up. any ideas? Gear shift drum not locked down in correct location? thanks Choctaw
Re: Ca77 transmission problem after rebuild
This may seem too basic but is it oiled up? I remember may Dad telling me he disassembled a 30.30 Winchester as a kid but after reassembly it was totally jammed. My Grampa suggested he lubricate it and it worked like a charm!
you know I wondered about that.I have just done a complete Restoration. new battery will be here Tuesday.I have kicked it over 6 times. I thought I would know more after i get it up and running and adjusted.before i pull the side cover off. Thanks! Choctaw
