Right Engine Cover Removal
Anything special I should know (or be warned) about when removing the right case? Thanx.
1966 CL77
You'll have to remove the footpeg bracket. Remove the 3 small phillips head screws, and the round alternator cover. Remove all of the phillips head screws that hold the cover on. Push the kick lever back to release spring tension, and wiggle the cover back and forth to remove. Nothing is going to fly out at you, and no oil will pour out.
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Thanks Davo
So the alternator cover screws into the motor, not the cover. Wouldn't have assumed that.
1966 CL77
Not exactly. The small round cover has three short screws which screw into the ends of special studs retaining the alternator.
Then the other screws hold the main cover to the crankcases.
Hold the kickstart lever when you remove the cover - it has a large spring which will try to make it rotate as you remove the cover.
