Fuel, fire and compression, but no start
hurdlesemo
Post by hurdlesemo » Mon Jun 20, 2011 6:34 pm
Just finished a motor rebuild of a 67 CB77. Got it all put back together - swapped out pistons with a spare set from a better bike, new plugs, plug wires, gaskets, condenser, points & plate.
Went to start it today and I've got compression - exhaust and intake - and fire at the plug but it isn't starting.
What is really weird is the fact that we had the throttle wide open and it never fired and the plugs are dry. Whenever I put my hands over the intake on the carbs they are wet with fuel, but it doesn't seem that it is getting in the cylinder. However I'm not sure that is the problem, but if it is any ideas?
Thanks
Josh
Quinn
Post by Quinn » Mon Jun 20, 2011 6:48 pm
put your hand over the carb with the throttle open and see if it pushes air against your hand or sucks
hurdlesemo
Post by hurdlesemo » Tue Jun 21, 2011 12:19 am
The carb is definitely sucking and it is sucking gas becasue my hand is wet with gas after some time.
Quinn
Post by Quinn » Tue Jun 21, 2011 1:24 pm
pull the plugs out spary some starting fluid in the spark plug holes put the plugs back in then try starting it if it doesnt fire then your having the same problem im having
Post by LOUD MOUSE » Tue Jun 21, 2011 3:14 pm
Please add your location to your profile. .........lm
hurdlesemo wrote:The carb is definitely sucking and it is sucking gas becasue my hand is wet with gas after some time.
hurdlesemo
Post by hurdlesemo » Tue Jun 21, 2011 3:50 pm
OK quick update.
Was doing some tinkering and this is what I found. Getting spark on the right side and when I switch wires from the condenser to the coils (switching green to yellow and yellow to green) I am getting spark on the left side but not on the right side.
So I changed out the condenser to an old one I had and same result.
I don't know now because the old condenser was just fine. Getting fire from both coils - one at a time when I switch wires. Plugs and wires are both new and getting good spark when I'm getting fire from the coils.
Could I have two condensers that the left side only is fouled on?
Any other ideas?
