Gas Tank Pressure Build-Up
marvincorty
Post by marvincorty » Mon Apr 17, 2006 10:27 am
I think there may be a problem with the gas tank cap on my CA78. After fueling with gas that is obviously cool and then letting the bike sit, pressure builds in the tank to a significant level. It gets high enough to force fuel past the carb float valve and cause the float bowl to overflow. I know the cap needs to vent inwards so fuel will flow to the carb but is this supposed to be a one way process or should it vent both ways? Has anyone else run into this same problem? Maybe the cap vent is not clear and I need to try and disassemble it if that is possible. Suggestions or ideas?
My money pit, so far;
1965 CA77
1966 A65 (yes a bezzer)
1971 SL100
1975 CB550
1976 CB360
1982 CR480R
2002 XR100
