Hi my speedo is inoperable on my new project. I disassembled and found that the speedo drive had seized and messed up the coil/spring which in turn galled up some of the numbers of the odometer spool. So if anyone has 4 black number dials and a spare speedo drive/spring/shaft, and a spare speedo needle, I could definitely put it to good use.
Also should mention mine is the type with the speedo that turns clockwise while accelerating.
Any help would be awesome!
Thanks, Jethro
