mix and match case halves
rrietman
Post by rrietman » Mon Oct 24, 2011 2:59 pm
are there any issues with swapping case halves? working on engine #CL72E 341264 and I have some old nasty weld repairs on the lower, however I do want that engine# to go in the bike I am working on. I built a bunch of these engines but always have used matching cases. I have lots of extra cases to pick from--- here are two I pulled out to look at---CL77E 1043281(some casting differences, but the important stuff matches up) CB72E 213911(castings match, but I would rather preserve this case for a future job) I have more CL/CB/dream cases to pick over.
I know if I was building a VW or Porsche motor I would not consider this kind of swap without an align bore.
Thanks
Randy
Re: mix and match case halves
Post by LOUD MOUSE » Mon Oct 24, 2011 3:55 pm
No problems as ya will find. ........lm
rrietman wrote:are there any issues with swapping case halves? working on engine #CL72E 341264 and I have some old nasty weld repairs on the lower, however I do want that engine# to go in the bike I am working on. I built a bunch of these engines but always have used matching cases. I have lots of extra cases to pick from--- here are two I pulled out to look at---CL77E 1043281(some casting differences, but the important stuff matches up) CB72E 213911(castings match, but I would rather preserve this case for a future job) I have more CL/CB/dream cases to pick over.
Thanks
Randy
kirbb9
Post by kirbb9 » Tue Oct 25, 2011 1:35 am
Hey LM, are these not lined bored? Or some other reason cases can be swapped?
Brady
66 CA77
2 GL's
ST 1300
hillhudson
Post by hillhudson » Tue Oct 25, 2011 2:02 am
I had to use two different cases, the bottom was from a '62 cb72 and the top case half from a '63 cb77
it has had no problems at all.
'65 s90
'64 ca95 dream
'65 cb160
'66 cb77
Post by LOUD MOUSE » Tue Oct 25, 2011 4:56 am
They were made really well and can be interchanged. ..............lm
kirbb9 wrote:Hey LM, are these not lined bored? Or some other reason cases can be swapped?
Brady
rrietman
Post by rrietman » Wed Oct 26, 2011 12:42 am
thank you LM, this is as would have thought given the design with roller bearings throughout. any engine using shell bearings I think would be quite a different story.
BTW I will be traveling in your parts next month and was thinking it might be fun to put a face with a name if you are up for a visit.
Thanks
Randy
Post by LOUD MOUSE » Wed Oct 26, 2011 8:37 am
Any idea what time span?. ................lm
rrietman wrote:thank you LM, this is as would have thought given the design with roller bearings throughout. any engine using shell bearings I think would be quite a different story.
Thanks
Randy
