No Power at 'R' Point or Spark
skisurf
Post by skisurf » Fri Nov 25, 2011 5:50 pm
I've been trying to follow Ed's tune up instructions and I can't for life of me get power from the "R" point. I've tried cleaning the points several times, nothing. Adjusting and re-adjusting, nothing. Moving the points plate around, nothing.
"L" side is completely fine.
I also tried testing my spark plugs and nothing on the right side.
Any ideas what the problem is?
skisurf
Post by skisurf » Fri Nov 25, 2011 7:01 pm
Played around with it a little more and the only time I can get any light at all is when the "r" side is open and I flick the "l" side. We're only talking a spark of light, the fastest little flicker. It won't stay on.
brewsky
Post by brewsky » Fri Nov 25, 2011 10:04 pm
Sounds like something is grounding........wire to points, points spring???
skisurf
Post by skisurf » Sat Nov 26, 2011 12:57 am
Good call. The condenser ground was bolted on the right side coil instead of the bolt holding the condenser to the coil.
