I am going to put my cl 77 engine back together and i want to make sure the kick start pawl that engages in the first gear is adjusted correctly, how far away should the spring and pin hold the pawl away from the first gear teeth that the pawl engages in the neutral position? Is the some spec. of 5 or 20 thou. or something?
Thanks for the help.
dave305
kick stsrt pawl adjustment
Re: kick stsrt pawl adjustment
Nothing to measure.
All parts fit that area. .............lm
dave305 wrote:I am going to put my cl 77 engine back together and i want to make sure the kick start pawl that engages in the first gear is adjusted correctly, how far away should the spring and pin hold the pawl away from the first gear teeth that the pawl engages in the neutral position? Is the some spec. of 5 or 20 thou. or something?
dave305
