Intake and Exhaust Valves, Swingarm bushings, Points Cam
Dickj
Post by Dickj » Wed Feb 01, 2012 3:05 pm
I need to locate Intake and exhaust valves for my 1966 CL77 Scrambler. Any suggestions??
I'm also looking for 2 new swingarm bushings for lower rear shock clevis. I had the old ones pressed out and one was OK but the other one was destroyed.
I also need a Points cam for the same engine. Mine is rough and corroded and the mechanic is afraid the seals will wear out fast.
I searched E-bay and other sources but came up dry.
Thanks, Dick J Santa Rosa. CA
Hoosier Tom
Post by Hoosier Tom » Wed Feb 01, 2012 6:30 pm
http://www.ebay.com/itm/Honda-CB77-CL77 ... 19bf8cfb4d
http://www.ebay.com/itm/Honda-CB77-CL77 ... 5d29b7d27d
You'll have to make sure to measure your points cam shaft diameter to get the proper one as there are 2 different ones.
I also found plenty of listings for CB77/CL77 valves.
HT
conbs
valves
Post by conbs » Thu Feb 02, 2012 10:33 am
Check for posts by LM on the valves. If I recall correctly he strongly recommends using Honda valves, but I can't remember exactly why.
Re: valves
Post by LOUD MOUSE » Thu Feb 02, 2012 1:23 pm
I sent a PM to ask why "New Valves.
So far no reply. ............lm
conbs wrote:Check for posts by LM on the valves. If I recall correctly he strongly recommends using Honda valves, but I can't remember exactly why.
