Can't separate float bowl from carb body
oldncapilot
Post by oldncapilot » Fri Feb 17, 2012 6:49 pm
My carb probably hasn't been apart since leaving the factory and I can't separate the float bowl from the carb body. I've tried tapping with a hammer and pulling with whatever strength I have but the gasket won't release it's grip. Does anyone have any tips for softening the gasket or getting the parts separated?
Re: Can't separate float bowl from carb body
Post by LOUD MOUSE » Fri Feb 17, 2012 8:13 pm
Hit it hard and if ya damage it so it needs ta be replaced get in touch with me or the list. .................lm
oldncapilot wrote:My carb probably hasn't been apart since leaving the factory and I can't separate the float bowl from the carb body. I've tried tapping with a hammer and pulling with whatever strength I have but the gasket won't release it's grip. Does anyone have any tips for softening the gasket or getting the parts separated?
brewsky
Post by brewsky » Fri Feb 17, 2012 8:14 pm
I would soak the joint with pb blaster or the like and heat with a heat gun/hair dryer.
Easy does it in a vise or with pliers
