Crankshaft sprocket retention nut... how to remove?
rzgkane
Post by rzgkane » Thu Feb 23, 2012 10:02 pm
Can someone tell me what needs to be done to get this nut off the end of the crankshaft? Is it left-handed thread? Do I need to hold the crank still? A special tool? More persuasion?
IMG_0624 by rzgkane, on Flickr
Post by davomoto » Thu Feb 23, 2012 10:58 pm
Normally a hammer and a dull chisel do the trick. If it's spinning, put a penny between the gear and sprocket to lock it up.
Davo
rzgkane
Post by rzgkane » Thu Feb 23, 2012 11:43 pm
davomoto wrote:Normally a hammer and a dull chisel do the trick. If it's spinning, put a penny between the gear and sprocket to lock it up.
Davo
Counter-clockwise, correct?
rrietman
Post by rrietman » Fri Feb 24, 2012 12:17 am
lefty loosey, righty tighty on this one. note how the dished washer is installed when taking it off, many get installed incorrectly.
Good luck
Randy
rzgkane
Post by rzgkane » Sat Feb 25, 2012 12:17 am
rrietman wrote:lefty loosey, righty tighty on this one. note how the dished washer is installed when taking it off, many get installed incorrectly.
Good luck
Randy
Busted three knuckles in the process, but I got it off. Thanks for the tips.
Re: Crankshaft sprocket retention nut... how to remove?
Post by LOUD MOUSE » Sat Feb 25, 2012 8:18 am
I would like to see pics of both ends of the oil filter. .........lm
rzgkane wrote:Can someone tell me what needs to be done to get this nut off the end of the crankshaft? Is it left-handed thread? Do I need to hold the crank still? A special tool? More persuasion?
DCON
Post by DCON » Sat Feb 25, 2012 8:50 am
Good luck
Randy
that beveled washer, sorry to hijack. just put mine on, is it correct that the umm ...ok lets call that washer an "ice cream cone". does the small end of the "cone" face the nut and the large face the sprocket? thats the way it came apart and some monkey was in here before. double checking
