Points lubrication...
rzgkane
Post by rzgkane » Mon Mar 12, 2012 12:07 pm
What's the preferable lube for the felt pad on a set of CA77 points?
briarpatch
Post by briarpatch » Fri Mar 16, 2012 9:28 pm
General Motors makes a points cam lube that works well. I have used Lubriplate. Lube the felt sparingly. LM may chime in with a better idea. THANKS - Stan
Post by LOUD MOUSE » Sat Mar 17, 2012 8:45 am
I use 30W non det. ...............lm
briarpatch wrote:General Motors makes a points cam lube that works well. I have used Lubriplate. Lube the felt sparingly. LM may chime in with a better idea. THANKS - Stan
briarpatch
Post by briarpatch » Sat Mar 17, 2012 3:25 pm
Well, LM, I can see how using 30w would let the lube wick up through the felt so the lube would last longer than putting Lubriplate on the wiping edge. Old dogs CAN learn new tricks! THANKS - Stan
