http://www.z1enterprises.com/Dyna-Singl ... -1542.aspx
Dyna Single Output 5.0 Ohm Coils (pair) DC10-1
DYDC10-1
OEM: DC10-1
5 ohm 12 volt black coils. Replacement for factory coils. Fatter spark means smoother running and less chance of fouling a plug. See below for plug wires.
Check the resistance of the coils you are replacing to ensure a correct match. If you have questions if these are correct, please call us or Dynatek at 1-800-928-3962
Never select a coil with a lower resistance than your ignition system - this will cause the coils to overheat and burn out... It is OK to select coils with a slightly higher resistance. For example 3.0 ohm coils with a 1.5 ohm CDI ignition. While this isn't optimal, it works and allows you to switch your CDI ignition over to a Dyna-S in the future.
