CLUTCH WIRE RING
CLUTCH WIRE RING
Hi all pulled the clutch plates out and according to the parts drawing there should be a wire ring between the first metal plate and first friction plate which it has but there is another 2 wire rings so i have 3 grooves in the clutch centre, is this correct and is the drawing wrong, and do these ring really need to be installed as mine are scrap as well as the plates.
Re: CLUTCH WIRE RING
Add your location to your profile.
There were 5 different center hubs and you have the 6 plate issue. ..........lm
STEVEUK wrote:Hi all pulled the clutch plates out and according to the parts drawing there should be a wire ring between the first metal plate and first friction plate which it has but there is another 2 wire rings so i have 3 grooves in the clutch centre, is this correct and is the drawing wrong, and do these ring really need to be installed as mine are scrap as well as the plates.
