JIS Pitch
quidger
JIS Pitch
Post by quidger » Fri Jun 01, 2012 8:16 pm
Someplace I have seen a JIS pitch chart that shows the pitch for each size of metric screw and bolt. At some point in the 70's the pitch on some sizes changed but I can't seem to locate a chart. I thought it was on my Bill Silver CD but can't even find it on there.
Can someone help me?
Thanks
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
OldHarley
Post by OldHarley » Wed Jun 06, 2012 4:51 pm
Guess there are no takers, so, I remembered seeing this well described chart that shows several types of JIS threads - parallel, tapered, etc.
http://www.ring-plug-thread-gages.com/t ... le-JIS.pdf
I would think that the metric standard (M) JIS is the one you need, but my experience is more on American bikes, so I am somewhat a novice at this.
I am still figuring out why the JIS fasteners on my '64 250 Dream aren't marked with a dimple or 'X' to help me out when I need a screw or bolt. At least then I would know the local hardware store didn't have any stock.
Oh well, maybe it is all JIS. So I continue to search.
Hotshoe
Post by Hotshoe » Wed Jun 06, 2012 6:01 pm
See if either one of these sites helps you.
www.mcmaster.com
http://mdmetric.com/tech/threadtech.pdf
brewsky
Post by brewsky » Thu Jun 07, 2012 5:22 am
The info is in the Bill Silver printed guide, so it should be there somewhere.
The change date was 1967 per Honda bulletin.
Basically, only the 3, 4, 5, and 12mm thread pitches changed. The rest are the same and interchangeable with current metric sizes.
The bolt head sizes (wrench sizes) changed on some others, but the pitch is ok.
rzgkane
Post by rzgkane » Thu Jun 07, 2012 10:40 am
Page 63 of Silver's Dream Restore 2010 file.
conbs
JIS
Post by conbs » Thu Jun 07, 2012 3:35 pm
I believe brewsky is right about the 4 sizes that are different. If I have my information correct the JIS pitches are as follows:
3mm is .6 pitch vs .5 pitch for ISO
4mm is .75 pitch vs .7 pitch for ISO
5mm is .9 pitch vs .8 pitch for ISO
12mm is 1.5 pitch vs 1.25 pitch for ISO
BTW this info is from Honda Service Letter #74 of 6/8/67 found on pg 63 of Bill Silver's 2006 Restoration Guide.
