Petcock Problem Question
Steve P.
Post by Steve P. » Fri Jun 22, 2012 5:55 pm
My CB77 petcock functions perfectly in the off position and reserve position. However I have no gas flow when it in the standard on position. Can any one give me a simple solution. I remove the bowl and try to run a piano wire up the hole when it is the on position and the wire wound not move very far.
THANKS!!!!!!
Steve
metrorollah
Re: Petcock Problem Question
Post by metrorollah » Sun Jul 15, 2012 10:59 pm
The cause of that is usually a rubber inner gasket instead of cork. I ditched mine and came up with this:
http://www.ebay.com/itm/271018122754
Steve P. wrote:My CB77 petcock functions perfectly in the off position and reserve position. However I have no gas flow when it in the standard on position. Can any one give me a simple solution. I remove the bowl and try to run a piano wire up the hole when it is the on position and the wire wound not move very far.
THANKS!!!!!!
Steve
