Electronic Ignition  -  CB72, CB77, CP77, CL72, CL77
Honda SuperHawk Electronic Ignition: CB72, CB77, CP77, CYP77
Electronic Ignition: FAQ
spacer
This FAQ (Frequently Asked Questions) section applies to the Electronic Ignition Systems for the 1959 to 1969 Honda 247cc and 305cc Twins.
Q.
A.
        Instructions
        Record
        Photos
Can I leave the ignition in the "on" position with the motor not running? If yes, for how long?
In a word - yes. Here is the full story:
The heart and brain of the Electronic Ignition system is the control module, AKA the "black box" or "module." The black box, as any electronic device generates heat. This heat must be dissipated in order to maintain the control module within a safe operating temperature range. The Electronic Ignition kits, described here, dissipate the heat by radiating it through a heat sink mounted on top of the control module. On a moving bike, the airflow facilitates the exchange of heat between the heat sink and the atmosphere. On a stationary bike, with the ignition on and the motor not running, airflow is minimal and the amount of time the ignition can remain in the "on" position is limited.
The current installation instructions specify that the ignition should not be left in the "on" position, with the engine not running (power-on/engine-off), for more than one minute. Changes to the transistors, heat sink, and potting since the original development was completed have made the earlier one-minute limit somewhat conservative. With this in mind, and in response to several questions on this topic, new tests were run (March, 2003) to determine how long it would be safe to leave the ignition in the "on" state with the engine not running (power-on/engine-off). The new test values apply to the Electronic Ignition systems with the integral type of the module heat sink. If your control module's heat sink is attached with a screw, these modified values do not apply, however the early designs were superceded rather early on in the production and the new values, discussed here, apply to the majority of the units sold over the past several years, as well as to those currently in production.
Please Note: In general, and regardless of whether your bike has the original points-type ignition or not, leaving the power on without starting the motor (power-on/engine-off) should be avoided, if only to reduce the chance of overheating the coils, and also to avoid the unnecessary battery drain.
The control module's self-heating can be more than twice as high with the engine stopped as when it is running. Furthermore, how much self-heating occurs is strongly dependent on the ignition coil's primary resistance. A low resistance coil (typically, a high-performance aftermarket coil) will lead to a higher current draw and higher module temperatures. The typical range of coil primary resistance is from about 5 ohms down to about 3 ohms (the stock CB/CL 72/77 coils have about a 4.5 ohm primary resistance).
The attached graph shows the results of three different tests performed, on CB/CL 72/77 motors equipped with the Electronic Ignition upgrade kits. The values are graphed on a time vs. temperature chart:
h305 e-Ignition: Time & Temp Chart
Time v. Temp Chart
The yellow line represents a running motor (power-on/motor-on), on a stationary motorcycle, with stock coils. The blue line represents a power-on/motor-off, with stock 4.5-ohm coils. The red line represents a power-on/motor-off, with high performance 3.0-ohm coils. Detailed explanations of the three tests follow:
Yellow Line: [Stock Coils, Ignition "on" Motor "on"]
The straight yellow line shows the “baseline” steady-state temperature of the module’s heat-sink fins in 70° F, still air, in the test lab, with a load of 1.22 amperes per coil, after nearly three hours of operation. This would be typical of a RUNNING Super Hawk or Scrambler engine with stock coils (4.5 ohms) and the battery at 14.5 volts (that is, being charged).
Under the conditions described above, the module temperature was stable at just under 99° F, feeling barely warm to the touch. With the addition of even very modest airflow over the fins, the temperature would drop much closer to the ambient air temperature, down to below 80° F. (Bear in mind that in Phoenix, Arizona, in the summer, with the air temperature at 115° F, the module would still run anywhere from 7° to 20° warmer than the air temperature. Depending on airflow, the corresponding fin temperatures might range from 122° F to 135° F, still perfectly safe for continuous operation and long life.)
Blue Line: [Stock Coils, Ignition "on" Motor "off"]
The blue line shows the temperature rise of the module fins, over the course of 15 minutes, with a load of 2.45 amperes, per coil, starting at about 73° F. The load of 2.45 amperes per coil would result from having the ignition on with the engine not running, stock 4.5-ohm Honda coils, and the battery terminal voltage at about 12.38 volts (as it would be under load, with the engine not running, and therefore not charging). After 15 minutes, the fin temperature reached 145° F, and the test was terminated. This fin temperature, while just high enough to feel “hot” to a prolonged touch of the hand, is still not hot enough to damage the module, but it is getting there. From the look of the curve, it appears that it would probably level off and stop getting any hotter at around the 160° F to 165° F level (with the ambient air at 70° F). While this would not damage the module, keep in mind that the same test in Phoenix, AZ, in the summer, might create fin temperatures exceeding 200° F, nearing the boiling point of water; this would be too hot for reliability. In summary: 15 minutes of module power-on with the engine stopped in a cool ambient temperature would not be excessive, and 7 or 8 minutes in a hot ambient temperature would not be unreasonable, using stock Honda 4.5 ohm coils. Note that one or both of the coils will also be getting hot under these conditions, and they may be less happy about the situation than the module, since their power dissipation is 8 or 9 times as high.
Red Line:  [High Performance Coils, Ignition "on" Motor "off"]
The graph’s red line shows the module fin temperature over 5 minutes of power-on/engine-off, with 3.5 amperes per coil - the equivalent of a 12.38-volt battery terminal voltage and 3-ohm (high-performance) ignition coils. In only 5 minutes, the high-current coils caused the module fins to reach over 160° F, where the test was ended. Note that the slope of the line was not even beginning to flatten out at 5 minutes, indicating that the module would have gotten very hot indeed. Again, if the module had started out at 115°F, for example: in Phoenix, AZ, in the summer, it would have reached about 200° F in only 1 or 2 minutes – again, too hot for reliability. The module may survive one, or even a few trips to that temperature, but then again, it may not. So, the rule for low-resistance, high-performance coils is close to the original conservative installation instructions guideline; 4 or 5 minutes starting out near 70° F is permissible for power-on/engine-off conditions in cool weather, and just 1 or 2 minutes in very hot-weather conditions.
In summary: try to avoid leaving the ignition "on" when the motor is "off" - this goes for any bike - and instead, turn both on and take the bike out for a nice ride!
