I took a CA77 out on the road yesterday, probably the first time it's run under its own power since the 80's, and first gear ran okay, but then in second it started to throttle intermittently, and also didn't seem to want to go into second - THAT could be a clutch adjustment problem, yes..?
But as far as the goopy throttle response, (stuttery, jerky, etc), that is *probably a dirty carb, yes...? I'm just asking for a second opinion...
Carb Question - Kinda Just Confirming...
Dr. Frankenstein
Geoff Hastings
If the points are adjusted correctly and all the ignition leads, coil, plugs etc are ok then almost certainly that carb needs another clean. Also, something I got caught out on was the insulator between the carb and head, on the ca it has a cutaway and a small bleed hole. Someone had fitted a plain insulator, changing for the correct one improved the response immensely.
Dr. Frankenstein
Geoff Hastings
