Does anyone have an suggestions for removing paint from my rear shocks? Someone painted the plastic covers with gray primer. I'd say about half of it has flaked off, and what's left is on there pretty good. I've chipped away as much as I can with my finger nail. I'd hate to use anything to scrape it off that would end up scratching the plastic.
I picked up my first dream last week. It's a '66 CA77. Hope to have it running real soon.
Thanks
Erich
Removing Paint
3BeanCrispy
bigscooter
Well I tried a few things that didn't seem to work very well, acetone, lacquer thinner, brake cleaner.
I ended up trying a little Jasco Paint and Epoxy remover on the back of a shock. It worked great and didn't do anything to the plastic. I only left it on for a minute or 2 before just rinsing most of the paint off with a hose. It took a couple applications to get them clean. The primer was only stubborn on part of the shock because the person who painted them didn't do a very good job sanding them completely.
Now I've got clean shocks with some light sand scuffs. Next question....is there a way to polish the plastic? There are some big scratches I know will never go away. And I know even repainting them wouldn't hide the marks. I would like to shine them up a bit so they don't look so "foggy"
Erich
ps. I picked up a 2nd dream today. I think it's a 67. Missing a few things, but it does have some nice original pipes, clean chainguard and the price was right. My projects are piling up!
Erich
bigscooter
I have a friend who polishs plastics, mainly antique radio's, for a living. I know the plastic on these things are probably different, but what is there to lose if you try a small spot on the back of the shroud? Start out with 1000 grit wet sandpaper and work your way up to 1500 or 2000. Use a buffer and some very fine compound or even wax might work, if you don't have a buffer you can tough it out by hand. Should work. I bought a bike with w/s that was all scratched up and some fairly deep ones I might add. I wet sanded it and buffed and it looks like new
