Starter button/switch questions I get a click....CA77
BrewCityDream
Cont....more pics
Post by BrewCityDream » Mon Sep 22, 2008 5:56 pm
more pics of the same dream
Post by davomoto » Tue Sep 23, 2008 3:21 pm
Sounds like tyou installed the slide in carb backwards. The long slot should face where the pin is inside carb, and small cutout towards idle screw. Find a correct replacement starter magnetic switch, not a generic bike barn one. Have you checked for spark while kicking bike? If you have spark, try a shot of starting fluid.
BrewCityDream
Post by BrewCityDream » Tue Sep 23, 2008 7:10 pm
That is the way I installed the carb slide, although thanks for the info so I know it's correct.
Next I'm gonna take apart the throttle at the grip as I had dissasmbled it a few times inpsecting the starter button and when the carb was removed and then re-installed it may need to be rechecked or adjusted if the throttle cable was twisted turned and pulled on. I noticed that was a tricky throttle assembly to get to sit right upon re-bolting down starter button assembly.
From most of the people I spoke to (Ohio Cyclery, & old honda guys) most 12v universal starter relays are good for many many applications from ATV's to motorcycles so I don't think that is the problem. I really would like to know is if a bad condenser can stop a bike from firing????
davomoto wrote:Sounds like tyou installed the slide in carb backwards. The long slot should face where the pin is inside carb, and small cutout towards idle screw. Find a correct replacement starter magnetic switch, not a generic bike barn one. Have you checked for spark while kicking bike? If you have spark, try a shot of starting fluid.
milwaukeephil
Post by milwaukeephil » Wed Sep 24, 2008 3:58 pm
Maybe I'll take a ride over on Saturday and see if I can help. I still have your cell#, I'll call you if I can get out...
Ford Guy
Electrical problems?
Post by Ford Guy » Wed Sep 24, 2008 4:00 pm
Hi
I am in the Milwaukee area. send me a PM and maybe I can help you out. I have a very busy schedule but maybe I can sneak a little time in some evening or weekend.
Jon
BrewCityDream
Post by BrewCityDream » Mon Sep 29, 2008 6:14 pm
Thanks Phil and Jon anything you can do to help will be greatly appreciated.
Post by e3steve » Wed Oct 08, 2008 12:29 am
You still there, Brew? Haven't disembowelled yourself over this, have you? Is you problem resolved? I mean, have you got the motor to spin over on the button? Obvious and fundamental questions: all the connections at the battery & solenoid are good? 3 wires at the +ve terminal -- starter (heavy), red & red/white?
Connect a jumper cable from somewhere on the motor (engine) to the battery -ve post; this will prove the earth return of the starter circuit.
Keep us informed.
