Do I have Oval or Square Carbs?
Spargett
Post by Spargett » Tue Nov 04, 2008 12:37 am
Loud Mouse, thanks again. You're a life saver. I got a the carb kits exchanged for the CB77 instead of the CL77, and it still came with a square gasket. Just ordered a pair of the round gaskets for $5.
Awesome.
LOUD MOUSE wrote:Ya can get the oval gaskets here. .............lm
<http://www.olypen.com/retro/>
Spargett wrote:I've been rebuilding my 64 CB77 carbs recently, and those look oval to me as well. I was actually sent a CL77 kit, which has square carbs. That's what set me off when I pulled out the square gasket next to my oval carbs.
Post by LOUD MOUSE » Tue Nov 04, 2008 2:53 am
You are welcome. .........lm
Spargett wrote:Loud Mouse, thanks again. You're a life saver. I got a the carb kits exchanged for the CB77 instead of the CL77, and it still came with a square gasket. Just ordered a pair of the round gaskets for $5.
Awesome.
RIDE IT DON'T HIDE IT!
Post by e3steve » Tue Nov 04, 2008 1:46 pm
Hey Scott, are you referring to your older carbs or the pair I sent you? Because I had both pairs, yours and my newer '67s, in front of me on the table; I'm bloody certain they're identical bowls! Or am I slipping into senility?
Spargett
Post by Spargett » Tue Nov 04, 2008 1:54 pm
Maybe I should have worded that better. They're most certainly both the same bowl shape. I just got square gaskets in the mail as opposed to the round variety. Of which I have just placed an order for the right sized gaskets per LOUD MOUSE's suggestion.
e3steve wrote:Hey Scott, are you referring to your older carbs or the pair I sent you? Because I had both pairs, yours and my newer '67s, in front of me on the table; I'm bloody certain they're identical bowls! Or am I slipping into senility?
Post by e3steve » Tue Nov 04, 2008 2:06 pm
Thanks. I really thought my eyes were deceiving me there and that maybe I should try some illegal recreational substances!!
Goodysnap
Post by Goodysnap » Sun Feb 22, 2009 7:50 pm
After getting my carb kits from Retro I realized from Lee's pictures I indeed have Oval carbs on my 64' . I realize all I should need is the oval bowl gaskets for rebuild. According to Bills manual they were used from 61-63. Did mine just happen to get Oval or is it more likely that they were changed at some point. Just curious more than anything. Thanks for your input.
64' CB77
65' CB160
Spargett
Post by Spargett » Sun Feb 22, 2009 8:02 pm
RetroBikes has the round carb gaskets for $2. Check em out in the carburetor section. Its where I ordered mine from.
Goodysnap wrote:After getting my carb kits from Retro I realized from Lee's pictures I indeed have Oval carbs on my 64' . I realize all I should need is the oval bowl gaskets for rebuild. According to Bills manual they were used from 61-63. Did mine just happen to get Oval or is it more likely that they were changed at some point. Just curious more than anything. Thanks for your input.
