Hi chico,
If beat blasting a used cylinder head, it's only is more time consuming, but the results will be comparable,
jensen
original finishing of the cylinder and cylinder head
jensen
- Contact:
Yes, I think it will be the same color, can you show us pictures to compare ?
The picture of the nos head (non-blasted) is to compare. Are you sure to use dull aluminum ?
As you can see on the pictures, the surface isn't dull, but shiny (not glossy).
