Scott, can you confirm that ?Scott didn't mention it but the engine has the 10 mm sparkplugs. I also took a peak at it at the swapmeet.
The frame and engine numbers are far apart, but that doesn't mean it's a later engine. I have seen more big differences between frame and engine numbers in the early bikes.
Thanks again,
Jensen.[/quote]
Jensen, I have confirmed what Toby said about the spark plugs, they are indeed 10mm. NGK plug in one hole is C-HS7.
