I have been using Rotella synthetic in all of my bikes since I purchased my 2005 V-strom 650.
No slippage, no problems. No leaks.
I have been a student of that Physics fellow referred to on this thread who has made a science of motor bike riding and maintenance. He has some good information.
So you are a VStom (WeeStrom) guy too, Davo?
Great bike, eh? I love mine but have found a new love for my old Honda recently.
By the way, I just discovered this somewhat ancient thread and I agree you cannot beat this to death. With each comment I read there is the possibility of finding a nugget of data or information.
George
Arizona
30W Non-detergent - Or is there something better?
Vince,
For some reason I thought I had put Rotella in my CL77, but today as I was doing some final touches on the bike I found my jug of oil and it is in fact, Rotella T.
This is what I ran in the bike last year and will run it until the gallon is gone and then will switch to the synthetic Rotella. She does smoke a tad and will be needing a rebuild one of these days. 14k+ on the odo. But she runs fine for now and doesn't leak(knocking on wood here).
All I can guess is the gray hair kicked in and adjusted my memory to believing I had put standard Rotella in mine. The Rotella T I'm running is 15W-40.
regards,
Rob
regards,
Rob
Goodysnap
I was unaware that Shell made a synthetic diesel oil in 15w40. I believe that both conventional and synthetic versions are labeled as (Rotella T). Rotella T synthetic I have seen is common but in 5w40. In the trucking industry alot of companies are finding that running the full synthetic oil after periods of running conventional ussually leads to increased oil consumption.
64' CB77
65' CB160
65' CB160
cyclon36
- Contact:
In general automotive circles, it is usually recommended that if you switch to a synthetic, to do so early on (within the first few oil changes). Otherwise, if you've run non synthetic for a period, it is best to keep using it.Goodysnap wrote:I was unaware that Shell made a synthetic diesel oil in 15w40. I believe that both conventional and synthetic versions are labeled as (Rotella T). Rotella T synthetic I have seen is common but in 5w40. In the trucking industry alot of companies are finding that running the full synthetic oil after periods of running conventional ussually leads to increased oil consumption.
jensen
- Contact:
Don't use 5W30 or 5W40 in these bikes, 5W is just too viscose, better use 10W40 or 10W50.
When using such thin oil the engine starts to consume oil, especially at the valve stem, remember, these engines don't use a valve stem seal.
- h305 Moderator
So, what's a guy to do?
I'll soon (in the ensuing few weeks) re-assemble my motor with the following NOS parts:
Any informed opinions gratefully considered!
- Gearbox bearings & bushings
Primary chain, 5-plate cush clutch -- no retaining rings (appears to be no provision for them)
Gudgeon pins, 0.1mm o/size
Pistons/rings (re-bored to 3rd over)
Valves & guides (I have the correctly-sized reamer)
Camshaft bearings, camchain & idler/tensioner
Vince Lupo
