I'm at a sticking point with my motor rebuild, i have come to the point where i need to rivot my cam chain together. Any tips would be great, should i buy a rivoting tool? Will this tool work on our chains? I have the chain installed with the link pushed in and the backing plate pressed on, i just have to rivot the ends so it can't slide out.
Thanks,
Brian
http://cgi.ebay.com/ebaymotors/Stockton ... ccessories
cam chain rivoting
Uniblob
Brian,
I use a large hammer as a backup on the backside of the sprocket and then simply peen the ends of the master link with the round end of a ball peen hammer. It's the only time I have ever used that tool for it's intended purpose, and by God, it does a pretty good job!
Regards,
Bruce from Baltimore
Regards,
linmictil
cam chain
I found a new "japanese motor cycle" cutter/riveting tool on ebay for a good enough price for me to buy it. I was going to try the hammer thing but didn't want to miss the rivet and screw everything up. Once you figure it out it is pretty slick..... mike
linmictil
cam chain
After sending you the site I seen the one you were looking at. The set looks to be the same one I bought. The smallest adapter works. That one is used but I think my new one was cheaper. mike
