superhawk 4 cyl.
bill440cars
mike horvath
superhawk 400f
Looking at the shifter, would'nt the pattern upshift/downshift be reversed? One up, four down? Nevertheless...cool looking bike.
Kev, if you had a stock CB72 lever pivot bolt, you could probably make it work like race kit change.
It might even be possible to move the pegs back to the stock front location with an arrangement similar to the stock linkage.
If you can't find a stock pivot bolt, use a longer regular bolt and machine a pivot the right size for the shifter and which just clears the bolt. Make it marginally wider than the shift lever so the lever isn't pinched.
You would have to dump the kicker and go with the electric foot of course.
