2 Questions!
Muddy
2 Questions!
Post by Muddy » Fri Aug 26, 2011 7:13 am
G'day From Australia
Can I ask 2 simple questions for a C72 (same as for CA72 of CA77), that I hope some people can answer in a bit of detail please:
Petcock Rebuild:
If I strip the fuel petcock for rebuilding, what do you use to reassemble the shaft to the top plate (the part I assume you have to drill out to separate the seals etc)?
Shock Absorber Rebuild:
Has anyone dis-assembled, rebuilt and reassembled a rear shock absorber (not the outer, but the actual oil filled damper)? Can this be done?
OK, so for the purists this was 3 questions?
Thanks
Regards
Muddy From Down Under
Thanks.
Regards
Muddy
'64 C72
'63 C72
Re: 2 Questions!
Post by LOUD MOUSE » Fri Aug 26, 2011 7:23 am
These folks have a valve kit.
<http://www.olypen.com/retro/>
The shock on the early issue should come apart.
Tough ta get the top cover off without special (make your own) tools.
Ya have ta compress the top cover to remove the top cover holders.
The seals may be tough to find so unless ya need to I'd not remove the shaft from the shock bottom. . ......lm
Muddy wrote:G'day From Australia
Petcock Rebuild:
Thanks
Regards
conbs
Petcock
Post by conbs » Wed Aug 31, 2011 11:51 am
The little shaft on the "fuel cock plate" is fits snugly in the hole in the body and is held in place by the 4 spring arms on the other side of it. Make sure the shaft can go as far into the body as needed to seal everything or your petcock will leak. I give the bottom of it a mild tap with a small hammer to make sure it will go in as far as needed. You should not need to drill anything.
Muddy
Post by Muddy » Fri Sep 02, 2011 8:18 pm
Thanks, guys. I may have to have a closer look at the fuel cock - looks like I've got things wrong!
I'll get back to you.
Thanks.
Regards
Muddy
Thanks.
Regards
Muddy
'64 C72
'63 C72
Tracepete
Post by Tracepete » Fri Sep 02, 2011 8:28 pm
Somewhere in here someone posted a step by step for the petcock rebuild along with pictures. If I can find it i will repost the link.
'67 Dream
'09 Suzuki TU250x
Muddy
Post by Muddy » Fri Sep 02, 2011 8:34 pm
Thanks tracepete, that would be great - I'll search myself as well
Regards
Muddy
Thanks.
Regards
Muddy
'64 C72
'63 C72
Tracepete
Post by Tracepete » Fri Sep 02, 2011 8:41 pm
'67 Dream
'09 Suzuki TU250x
