Now that you point that out Goody, I'm not sure.
An NGK spec page I found on-line lists the D range plugs as having 1.25mm thread pitch.
Spark plug threads
Spark Plug Threads
I bought a Spark Plug Chaser. Do you think using that would work, or cause more damage?
Re: Spark Plug Threads
May depend on how good you are with tools. ............lm
mattybpt wrote:I bought a Spark Plug Chaser. Do you think using that would work, or cause more damage?
Spark Plug Threads
Was planning on using grease in the chaser threads and slowly threading it into the spark plug hole. Is that what you would recommend or do u have any other suggestions? Thanks.
