Raising compression ratio
Hoosier Tom
Post by Hoosier Tom » Fri Oct 26, 2012 5:49 am
Jensen,
Well stated as G said. I was thinking the same thing about the front end. I could putt around all day on a Dream (with more padding on the seat for my boney butt), put I sure wouldn't want to tempt fate and try to stop quick at highway commuting speeds with that front end.
HT
jensey
Post by jensey » Fri Oct 26, 2012 6:33 am
Thanks for the comments.
btw, When I did the upholstering of my seat I placed gel pads on top of the foam, just underneath the cover. I read this tip on the hondatwins forum, sure it works !
Greener101
Post by Greener101 » Fri Oct 26, 2012 9:25 am
Thanks for the input guys.I really like the gel pads as I also suffer from the disease-no assitol.Living in a rural area the traffic is very light.I will definitely look to other options.I found a 81 Honda GL(?) 500 with the shaft drive.This could give reason to resurrect the old girl....maybe into an electric bike.Greener
Cheburashka
Post by Cheburashka » Fri Oct 26, 2012 10:02 am
I commuted on a GL500 for several years. They're very comfortable bikes, and they handle surprisingly well. Nice to have that fairing on there too!
Greener101
Post by Greener101 » Fri Oct 26, 2012 2:54 pm
Just for argument's sake,let's say I was able to acquire a set of the early four ring cl pistons that raised the the compression to 9.5:1,what combustion chamber volume would I need to reduce the compression to 9.1:1?What thickness gasket would accomplish this?Greener
jensey
Post by jensey » Sat Oct 27, 2012 1:16 am
good luck,
jensen
Post by G-Man » Sat Oct 27, 2012 2:55 am
Greener
Cylinder size is 152.5 cc
bore diameter is 60mm ( if STD)
Stroke is 54mm
Compression Ratio 9.5:1
Compression ratio is :-
Combustion Chamber Space Divided by (152.5cc + Combustion Chamber space)
Easy enough to work out from that.....
