Piston replacement set: $75
http://bore-tech.com/product/replacemen ... n-kit-p660
Head gasket: $42.50
http://bore-tech.com/product/head-gaske ... g-bore-kit
Thanks for the heads up. I'm still new to these bikes, so I hadn't heard there was a kickstarter issue. I'll do some reading up on that and see what I am getting myself into.sixtiescycle wrote:Keep in mind that as you raise the bore size you increase the chances of breaking the already delicate kickstarter.
I haven't got that far yet, but will look into it. I am hoping that the machining cost won't be more than what a completed kit would cost otherwise it won't make much sense to do it this way.conbs wrote:Awesome,
Using the 750 liners will require machining the head for them to fit. Have you calculated the amount of room you need/have to make sure they will fit? If not maybe you could Siamese them or something. Let us know what you find.
