Hi new member from Essex UK first post
Is it possible to change oil seals on offside of engine without spliting cases.
\have oil leak on newly aquired bike otherwise running fine.
Cb 72 1965
Ray
oil seals
Re: oil seals
You may find the seal at the clutch rod is the problem.
No problem removing or installing a new one.
If you find the leak is with a seal in the cases I recommend you use a knife and cut the sharp edge of the case at that location.
Do Not put any sealer as Permatex as the seal will pop out as you ride. ......lm
raygray11 wrote:Hi new member from Essex UK first post
Cb 72 1965
Ray
Any luck on the issue ray?
Congrats on the Honda, sounds like you're racking up the cool bikes.
