Wanted Rear Winkers 305 Dream
catterar
Post by catterar » Fri Dec 20, 2013 9:00 am
I'm looking for a set of rear winkers for a 305 Dream. Anyone have a pair they want to sell.
I have the fronts, right hand switch and flasher, just need the rears to complete the set-up.
Thanks,
Bob
conbs
Rear Winkers
Post by conbs » Sun Dec 22, 2013 12:41 pm
CA77 or CA78?
catterar
Post by catterar » Mon Dec 23, 2013 10:54 am
CA78 Frame Number CA78-1021025.
Bob
conbs
CA78 winkers
Post by conbs » Mon Dec 23, 2013 11:15 am
You can buy lenses from Asia; OEM or cheap re-pops. The tail light screws will work to mount them. You can fab a seal.
Finding an OEM bulb holder is very difficult, but, NAPA should have a light from which you could rob some if you do a little looking.
This won't technically be OEM, but no one would be able to tell when it is assembled.
Hope that helps.
catterar
Post by catterar » Mon Dec 23, 2013 1:16 pm
conbs wrote:You can buy lenses from Asia; OEM or cheap re-pops. The tail light screws will work to mount them. You can fab a seal.
Hope that helps.
I have thought about going this route but when I search ebay it appears that there is a wedge shaped piece that fits between the lense and the shock bracket http://www.ebay.com/itm/Honda-Dream-Ben ... 1480wt_970.
So far I have only been able to locate the left hand piece. I don't want to buy just one side so I'm waiting until I can locate both sides.
Bob
conbs
CA78 winkers
Post by conbs » Mon Dec 23, 2013 4:09 pm
That wedge piece is for CA77 winkers and mounts on the fender. You don't need them.
For the CA78 you can just remove the plate at the back of the luggage supports and the winker lens mounts right there. Hole for the screws should be there ready to go.
catterar
Re: CA78 winkers
Post by catterar » Mon Dec 23, 2013 5:24 pm
conbs wrote:That wedge piece is for CA77 winkers and mounts on the fender. You don't need them.
OK! Thanks, I didn't realize that. I'd been going by pictures on the internet. I'll get my self some lenses and rig up some kind of light socket and should be good to go.
Bob
