1966 honda dream ca77 petcock question
Re: 1966 honda dream ca77 petcock question
Post by LOUD MOUSE » Sun Nov 08, 2015 11:59 am
I thought I had one of these but I find the gas hose tube is on the left not the right like you have there. .............lm
choctaw wrote:I have been trying to remove these 3 screws. I have used. wd-40,pf blaster,liquid wrench, a mixture of 50/50 transmission fluid and acetone. I have had no luck. I have let it set for 2-3 days on all the fluids I mentioned. I even used a impact screwdriver,any ideas?
mike1969
petcock
Post by mike1969 » Sun Nov 08, 2015 2:13 pm
Gman, I know using different fasteners make an engineer cringe.
When you purchase a petcock rebuild kit they come with metric, non JIS fasteners. If you want to use them you have to tap the holes. I went with SAE stainless screws, so they will probably last for many,many years.
Re: petcock
Post by G-Man » Sun Nov 08, 2015 2:31 pm
Mike
As long as they fit properly I don't have a problem... :-)
I don't like re-tapping with the same size but a different thread pitch - it will never be as strong.
And, I hate to see this......
I did similar things when I was 13 or 14 but education is a very powerful tool which should be applied liberally ..... :-)
mike1969 wrote:Gman, I know using different fasteners make an engineer cringe.
Re: petcock
Post by LOUD MOUSE » Sun Nov 08, 2015 3:05 pm
When I see allen screws on a fellers engine I mention that "Your engine must be a race engine with those screws".
You can imagine the reply's I get!. ...........lm
G-Man wrote:Mike
mike1969
petcock screws
Post by mike1969 » Sun Nov 08, 2015 4:06 pm
One thing I have learned from experience is to never try to re-use 50 year old corroded stripped screws to secure a petcock to a fuel tank.
Re: petcock screws
Post by G-Man » Sun Nov 08, 2015 4:30 pm
Indeed ... :-)
mike1969 wrote:One thing I have learned from experience is to never try to re-use 50 year old corroded stripped screws to secure a petcock to a fuel tank.
Re: petcock screws
Post by LOUD MOUSE » Sun Nov 08, 2015 5:58 pm
I don't use stripped screws no matter the vintage. ............lm
