Left Cylinder Has Intermittent Spark
Cap'n Dave
Post by Cap'n Dave » Mon May 21, 2018 6:33 pm
My CP77 is difficult to start and then I realized that the left cylinder wasn't firing. If I pulled the spark cap off the about 1/4" it would start to fire. Few minutes later I would press the cap on fully and it was fine.
Anybody have any ideas ?
Re: Left Cylinder Has Intermittent Spark
Post by G-Man » Tue May 22, 2018 12:31 am
Plugs clean and fresh?
Carbs jetted correctly?
Ignition timing set properly?
Try swapping ignition parts (plugs / caps ) left tyo right.
By pulling the lead away from the plug you have essentially incresed the voltage at the plug points.
Cap'n Dave wrote:My CP77 is difficult to start and then I realized that the left cylinder wasn't firing. If I pulled the spark cap off the about 1/4" it would start to fire. Few minutes later I would press the cap on fully and it was fine.
GregMcN
Post by GregMcN » Thu May 24, 2018 1:18 pm
A couple of problems I have had are a poor connection between the plug lead and the cap ( fixed by cutting a little bit off the lead and rejoining) and also plugs that have just not fired consistently but easily checked by swapping them over.
Greg
