superhawk 4 cyl.
bill440cars
Post by bill440cars » Thu Aug 04, 2011 11:06 pm
Looks pretty cool, Kevin. Listen, I forgot to get that picture off to you, so I am going to do it now. Sorry bout the delay.
Working Toward Being Able To Work On MY Motorcycle Projects (Trying To Get Past "Other" Projects & I Think I Am Making Progress?
Hahnda
Post by Hahnda » Thu Aug 04, 2011 11:16 pm
Don't worry about it to much Bill.
Made a few changes to it at the request of the current owner. It also got a bit of a clean-up.
teazer
Post by teazer » Sat Aug 06, 2011 9:58 am
That's looking much better.
mike horvath
superhawk 400f
Post by mike horvath » Sat Aug 06, 2011 11:53 pm
Looking at the shifter, would'nt the pattern upshift/downshift be reversed? One up, four down? Nevertheless...cool looking bike.
Hahnda
Post by Hahnda » Sun Aug 07, 2011 3:25 pm
Yes shift pattern is now reversed from the original pattern.
teazer
Post by teazer » Mon Aug 08, 2011 11:48 am
Kev, if you had a stock CB72 lever pivot bolt, you could probably make it work like race kit change.
It might even be possible to move the pegs back to the stock front location with an arrangement similar to the stock linkage.
If you can't find a stock pivot bolt, use a longer regular bolt and machine a pivot the right size for the shifter and which just clears the bolt. Make it marginally wider than the shift lever so the lever isn't pinched.
You would have to dump the kicker and go with the electric foot of course.
Hahnda
Post by Hahnda » Mon Aug 08, 2011 11:51 am
I agree some of the stock bits could be used to get the linkage back to a more normal pattern and look. The shift side could be moved back to stock location but the brake side cannot be moved unless the kicker was removed. Actually I don't mind this shift patter, it shifts like my old Guzzi.
