[ From an Email Question - 09.17.06 ]
Question for anyone who has installed the Electronic Ignition Upgrade kit on a CL72 or CL77 bike:
Where did you mount the Module?
Module on CL77 - Where did you mount it?
- Michael Stoic
- Contact:
Re: Module on CL77 - Where did you mount it?
First you need the (L) kit because 12 inches were added to the wire harness. You install it on the top of the rear fender behind the battery and split the wires on each side of the frame as you install the plate and connect to the coils. I get battery from the coil hot lead and ground to one of the frame/coil mount screws. ............lm
Michael Stoic wrote:[ From an Email Question - 09.17.06 ]
