kickstart setup
kickstart setup
does anyone have any informatiom on setting up the kickstarter on 1964 cb72 uk version??.<br />dots on gears are visable.
georGe
Re: kickstart setup
Yes I know how to set up the kick mech, if ya still need help post again and ill help ya.Ill be frequenting the boards again.<br /><br />georGe
stew_bidasso
Re: kickstart setup
Sorry to highjack your thread, but, I have just instaled a new kick start lever on my 1963 cb72, after it is started it will not stay in the up position and makes a funny noise when in nuetral. Any help is appriciated in advance.
Kickstart setup -- still wondering
Am curious about kickstart setup myself. Any advice out there?
I've gone all the way back through the threads and can't seem to find anything.
Re: Kickstart setup -- still wondering
On the Scrambler you turn the KS shaft clockwise to stop. Lube the splines (white grease) and locate the KS lever at 12:00 and slide cover on. Now with the KS lever turned in it MUST index at 11:00 because if it's more toward 12:00/1:00 you will hit the internal stop and twist the splined end off the KS shaft. .........................lm
wordman5 wrote:Am curious about kickstart setup myself. Any advice out there?
