Stripped oil plug
CBasket
Stripped oil plug
Post by CBasket » Fri Aug 13, 2004 11:46 am
I have tried to change the oil in a CB77 that I bought recently, but the oil plug is stripped. It's loose, but doesn't unscrew. Does anyone have any experience re-tapping this? Is it possible or even advisable?<br /><br />Thanks,<br />Scott
georGe
Re: Stripped oil plug
Post by georGe » Thu Aug 19, 2004 4:59 pm
You can pull the whole oil pump assembly out pretty easily in order to re-tap the drain hole. That would be best as you can get to the hole from both sides. <br /><br />georGe
