volts?
volts?
Hi,<br />Checked the key switch, it works, as do all the other components. This leaves the coils or the magnets. What voltage should I be getting off the stator coils? I'm getting a good 6 volts from each pair.<br /><br />cheers,<br />chriso
Re: volts?
It is because I am using the starter motor, and not the kick start. This meand that the magnets were not spinning fast enough to produce the correct voltage. Sadly, still no spark...
georGe
Re: volts?
What kinda shape is the battery in ? Have ya checked the coil and are you even getting a signal going into the coil ?<br /><br />georGe<br />
Re: volts?
The battery is OK, I cannot find the proper one, but I came close. 12V at 7AH. I have not gotten power to the coil yet. I'm checking the switch, and the wires tomorrow. This is getting annoying. Good thing I drive a Russian bike too, great for teaching patience.<br /><br />chriso
georGe
Re: volts?
I understand ya have to have ALOT of patience w/ Russian bikes ! LoL<br />If your getting power coming out of the generator but not getting to the primary of the coil then something is not right in the points/condensor It doesnt seem as though its making a complete circuit.<br /><br />georGe
