Maintenance for CB77 Oil filter
Fastwater
Post by Fastwater » Wed Oct 08, 2008 12:40 pm
Does the oil filter in the Superhawk 305 engine require maintenance?
I realize it is centrifugal but where does all the badness go? With that, is it difficult to check?
Post by e3steve » Wed Oct 15, 2008 3:17 pm
You need to remove it, disassemble and clean it out. Don't try to be a gynacologist and remove it through the access cover; be sure to have a new clutch cover gasket to hand, drain the oil, remove the clutch / l/h crankcase cover to access the filter.
When refitting, remove the round access cover from the main cover and refit the main cover first. There should be a thrust washer that goes on the filter shaft between the filter itself and the crankcase, not between the filter and the round access cover.
BIG BLOODY NOTA BENE: What I wrote above is total bollox; please read the rest of this topic -- including my retraction!
Post by LOUD MOUSE » Thu Oct 23, 2008 5:01 pm
The washer goes on the shaft first then the filter.
If the washer isn't on that end the filter cap will eat the cover at the shaft area. (aluminum against aluminum). ................lm
e3steve wrote:You need to remove it, disassemble and clean it out. Don't try to be a gynacologist and remove it through the access cover; be sure to have a new clutch cover gasket to hand, drain the oil, remove the clutch / l/h crankcase cover to access the filter.
RIDE IT DON'T HIDE IT!
gramey7
Post by gramey7 » Fri Oct 24, 2008 10:45 am
Now I'M confused. The CL77 Parts Catalog shows the washer being instlled adjacent to the shaft pin. Also Bill Silver's Resto guide says to "install the thrust washer outside of the filter assembly, next to the shaft locating pin."
I'm not sure this is really a "thrust" washer anyway, since there are no lateral loads on the filter. I suspect it provides a buffer between the filter and the shaft pin.
deaddog
Post by deaddog » Fri Oct 24, 2008 10:56 am
LOUD MOUSE wrote:The washer goes on the shaft first then the filter.
Do yourself a favor and listen to Loud Mouse. This has been discussed in length on other threads.
Post by LOUD MOUSE » Fri Oct 24, 2008 5:14 pm
You have the correct location but the washer never touches the pin.
Put it on the wrong end and ride a 1000 miles and you will see how much thrust there is at that location. (aluminum against aluminum eats aluminum). ...............lm
gramey7 wrote:Now I'M confused. The CL77 Parts Catalog shows the washer being instlled adjacent to the shaft pin. Also Bill Silver's Resto guide says to "install the thrust washer outside of the filter assembly, next to the shaft locating pin."
gramey7
Post by gramey7 » Sat Oct 25, 2008 11:51 am
Thanks LM and deadog for clearing that up; I wasn't intending to question anyone's expertise, just to clarify the correct location.
