I just replaced my throttle cable, and threw on a "new" set of carbs. Everything is great and smooth as butter, but I've noticed that the right carb's valve gets stuck if I pull back the throttle COMPLETELY. The only way to un-stick the valve is to rock the throttle cable at the top of the carb, at which point it drops right back down.
Any ideas on what might be causing this?
Note: I just rebuilt the carbs and the throttle cable is brand new. The bike is a 62 CB77 with a pair of 64 carbs.
Right carbs valve sticks on full throttle
I loosened the nuts up and it seems to have fixed the problem. I haven't been able to replicate it sticking since, so we'll have to see over time. But I'm 90% that was it. Such simple things it can be sometimes. Thanks for the tip ; )
How loose would you say is acceptable? Do you think the ability to turn the nut by hand without moderate difficulty too loose?
rgtaylor2 wrote:You may have the nuts a little tight on that carb, back them off a bit and see if it helps.
"Strip"?
deez wrote:tighten them one turn past strip then back it off one.
