I have a 65 CA77.
Bike was running rich/ high idle, but after running bike it would want to idle so low that it would die...and fouling plugs...
running much more smoothe now, lower , but consistent idle, good acceleration.
after many attempts i have come to these settings:
Needle is in top notch (sitting lowest in jet)
Slide screw is alomst all the wat out
air screw is all the way to bottom less about 1/8th turn
float height 26.5~27mm
other info:
NOS carb. 35 slow jet. can't find nunmber on main jet. have nos paper airfilter attached. carb nuts not overtightened. valve clearance to spec.
Still Idles a bit high (no tach, however on ca77)....checking tonight to see if plugs fouled....
this whole set up just seems wrong.
Any thoughts?
crazy settings needle/air screw/ slide screw
Re: crazy settings needle/air screw/ slide screw
You for sure have something out of sorts with the way you have the carb adjusted. ............lm
versuspop wrote:I have a 65 CA77.
other info:
Any thoughts?
still fouling plugs with previous set up sooooo....
i have switched to a 115 main jet and the original needle.
now it will not start. back fires on ignition. (assumed to be lean now. verify, anyone?)
i switched to the 115 main jet because that was what was in the original carb.
i also have a 130 for a keyster kit.
